Date/Time: Sun, 28 Apr 2024 15:24:52 +0000
Bitcoin trading on SC (exchanges/feeds)
View Count: 1917
[2017-07-19 16:39:45] |
rhovega - Posts: 279 |
Are Bitmex and Bitfinex the only alternatives currently available for trading bitcoin in SC? (those are the only showing as 'Trading' in Data/Trade Service Settings). Thank you.
[2017-07-19 18:07:34] |
Only BitMEX is supported for trading. Bitfinex is not.
[2017-12-09 18:54:54] |
User559414 - Posts: 2 |
Are you planning to add Bitfinex?
[2017-12-11 04:03:59] |
Yes.
