Date/Time: Sun, 05 May 2024 22:15:22 +0000
hand tool with crosshairs always on
View Count: 1521
[2013-08-30 16:22:57] |
M5amhan - Posts: 468 |
when you have the crosshairs always on with any tool, there is no way to make it disappear so if you hover over a chart it stays on forever. would it be possible to add an option for "only show on active chart" so it would automatically disappear when your cursor leaves the chart? thanks |
[2013-09-07 02:06:21] |
This will be solved in the next release.
