Date/Time: Sun, 05 May 2024 08:14:32 +0000
Error: Custom study needs to be recompiled
View Count: 1364
[2013-08-30 14:48:04] |
emp0804 - Posts: 31 |
Hi Support, I'm getting this error message in the log file: Custom study needs to be recompiled for this version of Sierra Chart. | 2013-08-30 09:05:45 Custom study needs to be recompiled for this version of Sierra Chart. | 2013-08-30 09:10:24 Custom study needs to be recompiled for this version of Sierra Chart. | 2013-08-30 09:14:29 Custom study needs to be recompiled for this version of Sierra Chart. | 2013-08-30 09:25:19 Custom study needs to be recompiled for this version of Sierra Chart. | 2013-08-30 09:32:23 Custom study needs to be recompiled for this version of Sierra Chart. | 2013-08-30 09:35:35 Which custom study is this? |
[2013-08-30 18:40:58] |
There is no way to know specifically which one because it is not possible to determine that safely. Do you have access to the source code for the custom studies you are using? If so, then all of them should be recompiled. Here are the instructions: http://www.sierrachart.com/index.php?l=doc/doc_BuildCustomStudiesDLL.html Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
