Date/Time: Sun, 05 May 2024 21:52:38 +0000
Order Strategy Advice
View Count: 1347
[2013-08-29 23:25:59] |
No, this is not supported. If the stop loss is triggered, then that will be filled and no other action will be taken. Other than canceling the target order. To do something more advanced like this, is more in the area of automated trading within Sierra Chart. You can look at spreadsheet automated trading: http://www.sierrachart.com/index.php?l=doc/doc_SystemsAlerts.php Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2013-08-29 23:26:40
[2013-08-30 21:05:05] |
This is not supported. All of the order types are documented here: http://www.sierrachart.com/index.php?l=doc/doc_OrderTypes.html Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2013-08-30 21:05:29
