Date/Time: Sat, 18 May 2024 06:02:00 +0000
Depth of Market Data and Spreadsheet System/Alert
View Count: 934
[2017-07-10 13:20:41] |
TSiSVT - Posts: 21 |
Would it be possible to show the Bid and Ask totals along with their respective percentage of the Depth of Market study to the Spreadsheet? See the attached image for reference.
Screenshot_1.png / V - Attached On 2017-07-10 13:19:27 UTC - Size: 15.9 KB - 271 views |
[2017-07-10 17:45:42] |
No, because those calculations would be inconsistent with the particular Subgraphs they would be contained within. You need to calculate these yourself. This is easy enough to do with available cells on the Spreadsheet.
Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2017-07-10 17:46:12
