Date/Time: Mon, 06 May 2024 01:25:41 +0000
Bollinger Band Squeeze TTM Squeeze
View Count: 5091
[2017-07-09 23:58:31] |
User509820 - Posts: 69 |
Hello, I am interested in a study called TTM Squeeze I have used it on other platforms(Thinkorswim). I read another thread saying the Bollinger Band Squeeze studies are the same as TTMS. Unfortunately I can't get the study to perform like the original TTM Squeeze. Tried adjusting settings but cannot seem to get it right. I have a code on how it is setup on another platform. Is there a way to get it working the same? def nK = 1.5; def nBB = 2.0; def lengthsqueeze = 20; def BBHalfWidth = StDev(price, lengthsqueeze); def KCHalfWidth = nK * Average(TrueRange(h, c, l), lengthsqueeze); def isSqueezed = nBB * BBHalfWidth / KCHalfWidth < 1; |
[2017-07-10 00:03:08] |
Where did you get this formula from?
[2017-07-10 00:20:56] |
I got this code from my study on thinkorswim. These are the same settings used on the TTM Squeeze. I use the study mostly to show when it is in a squeeze. But with the current Bollinger Band Squeeze settings the data is not quite the same.
Date Time Of Last Edit: 2017-07-10 04:12:56
[2017-07-12 05:11:59] |
Letting you know we just need some more time to follow up on this. We will have a closer look next week and see if we can adapt one of the existing studies to do exactly the formula you provided if it is not already supported. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2017-07-12 05:12:12
[2017-07-12 05:41:25] |
I also have a tradestation study download of the indicator and a photo. If this will be of any help. Thanks http://cdn3.traderslaboratory.com/forums/attachments/46/166d1161489975-bb-squeeze-replica-tradestation-bb_squeeze.eld Date Time Of Last Edit: 2017-07-12 05:44:45
IMG_6895.JPG / V - Attached On 2017-07-12 05:38:05 UTC - Size: 78.97 KB - 1516 views IMG_6895.JPG / V - Attached On 2017-07-12 05:38:51 UTC - Size: 78.97 KB - 586 views |
[2017-07-21 23:06:01] |
We got delayed with this, but we are going to be looking it over in the next few days.
Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2017-07-21 23:06:18
[2017-08-01 21:07:48] |
Hey any update of this study? Thanks
[2017-08-02 18:07:42] |
We still have not yet completed the review.
[2017-08-15 14:44:24] |
User836376 - Posts: 2 |
Whats the update on this indicator? I'm also interested in the TTM Squeeze the bollinger band squeeze you have does not fit with my strategy due to different settings then John Carters TTM Squeeze settings. Whats the time frame that this will be finished and ready to use? Thank you for your hard work!!!
[2017-08-16 17:35:05] |
nicktrader - Posts: 665 |
I am also interested in John Carters TTM Squeeze
[2017-08-16 18:08:13] |
We are getting close to finishing this.
[2017-08-22 04:35:31] |
In the next release, there will be a Bollinger Squeeze 3 study coded according to this: def nK = 1.5;
def nBB = 2.0; def lengthsqueeze = 20; def BBHalfWidth = StDev(price, lengthsqueeze); def KCHalfWidth = nK * Average(TrueRange(h, c, l), lengthsqueeze); def isSqueezed = nBB * BBHalfWidth / KCHalfWidth < 1; Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
