Date/Time: Sun, 04 Oct 2026 05:57:23 +0000
Not able to download a .cpp files from the old Support Board
View Count: 1652
| [2017-07-05 10:47:08] |
| User93757 - Posts: 61 |
Hi, I was trying to download a .cpp file from an old post. Does not seem to be working. Ty, http://www.sierrachart.com/supportboard/showpost.php?p=232314&postcount=24 bgmvwp2.cpp |
| [2017-07-05 15:49:56] |
We will check on this.
| [2017-07-05 19:20:38] |
This has been fixed.
Sierra Chart Support |
| [2017-07-06 05:45:43] |
Strange.. it's working on my phone, but not chrome or explorer browser....
| [2017-07-06 19:15:01] |
We tested with Firefox, Chrome and IE and it works on all. Restart your browser and try again. Sierra Chart Support |
| [2017-07-06 19:15:04] |
| [2017-07-07 04:40:00] |
Don't know if it is a local issue or an issue with the web server. When i click on the link, i get the following address; http://www.sierrachart.com/supportboard/attachment.php?attachmentid=10260&d=1359555235 If i change the http:// to https://, I am then able to download the file... ie. https://www.sierrachart.com/supportboard/attachment.php?attachmentid=10260&d=1359555235 Anyhow, i've got the files and thank you for your support. |
| [2017-07-07 16:13:30] |
That must be a local issue. Both links work correctly on our end, on multiple different browsers and computers. A TLS connection should not and does not really matter in this case. The only difference a TLS encrypted (https) connection has is that it stops your ISP and/or others from injecting additional data like ads and/or trackers to pages: https://www.privateinternetaccess.com/blog/2016/12/comcast-still-uses-mitm-javascript-injection-serve-unwanted-ads-messages/ The only issue that we do see is with older versions of IE, where the file is downloaded but it is not given the correct name. This is not an issue with the latest version of said browser. Sierra Chart Support Date Time Of Last Edit: 2017-07-07 16:18:01
