Date/Time: Sat, 18 May 2024 04:38:12 +0000
AUDUSD Data issue
View Count: 758
[2017-07-04 20:34:19] |
User499178 - Posts: 2 |
Hello there, i use the sierrachart datafeed, and always if i load the audusd there are missing severel months of data. i ad also a picture than you can see what i mean. what do you need from me that you can help me? see you |
Attachment Deleted. Private File |
[2017-07-04 21:24:45] |
Follow through the instructions here: Historical Intraday Data (Missing Data / Download Errors / Viewing More Data): Retrying the Download When There is Data in the Chart Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2017-07-07 14:51:01] |
and how i can save the data ?? always when i change the chart symbol sierrachart does load again the data from the server ?
[2017-07-07 14:54:04] |
The data is automatically saved. There is nothing special you need to do. When you do change the symbol of the chart, then any missing data is downloaded if it has not already been. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
