Date/Time: Sat, 18 May 2024 16:33:00 +0000
Bitmex Order Types
View Count: 2053
[2017-07-04 20:05:32] |
User989712 - Posts: 27 |
Are all these order types on the Bitmex server, that is, if the internet connection goes down between Bitmex and SierraChart, are the orders entered still active on the server? https://www.bitmex.com/app/orderTypeFAQ#Trailing-Stop-Order-Example Thanks |
[2017-07-04 21:03:33] |
In the case of Attached Orders this is explained here: Attached Orders: General Management of Attached Orders Server-side OCO and bracket orders are supported with BitMEX. Server-side trailing stops are not supported with any service and never will be. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2017-07-04 21:04:23
[2017-07-04 23:24:57] |
CTS also does not provide server side trailing stops? Thanks |
[2017-07-05 03:04:29] |
We are not sure whether they are provided by CTS or not. Probably within their own software. But they are not supported by Sierra Chart.
