Date/Time: Sat, 18 May 2024 14:09:54 +0000
My TICK NYSE data is in minutes until 2014. Can I get better resolution data?
View Count: 630
[2017-07-04 19:43:11] |
maxima120 - Posts: 144 |
is it the best we can get or is something wrong with my settings? (I have 10000 days tick data set in the data settings) and afterwards its in seconds. I thought you said you have at least 4 updates per second for market stats. where is no milliseconds stamp. what am I doing wrong? |
[2017-07-04 19:57:40] |
Yes, before that time, the data is in minutes. There is more than one update per second, but the data is stored in one second units. We cannot comment on this further. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
