Date/Time: Thu, 02 May 2024 13:29:14 +0000
Ten year monthly charts
View Count: 1246
[2013-08-29 07:34:53] |
User123496 - Posts: 27 |
Dear Tech Supt., I need to construct monthly charts for the Eurodollar, E mini,British Pound and the Aussie Dollar from Jan. 2003 to the present. If this is possible, please, tell me how to get the data. I believe I can then construct it from within a Chartbook. Thank you, Alan Date Time Of Last Edit: 2013-08-29 08:19:24
[2013-08-29 08:19:11] |
This is supported. Please follow method 2 here: https://www.sierrachart.com/index.php?l=doc/doc_ContinuousFuturesContractCharts.html#Method2 If you are using TransAct, you can find the long-term continuous futures contract symbols under File >> Find Symbol. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
