Date/Time: Sun, 05 May 2024 15:32:57 +0000
SMI double,two Time Frame ,same Chart
View Count: 1272
[2013-08-29 06:28:15] |
User45578 - Posts: 49 |
How getting on a same chart of a Time Frame of 30mn for exemple on a same subgraph two SMI,one of a Time Frame the same of the Main Chart and the other whith a Time Frame 150mn it is to say five time more.Thaks a lot.
[2013-08-29 18:37:41] |
vegasfoster - Posts: 444 |
Try this http://www.sierrachart.com/index.php?l=doc/helpdetails28.html
[2013-09-03 17:25:09] |
This can be done. Refer to the instructions in help topic 28 here: Http://www.sierrachart.com/index.php?l=doc/helpdetails28.html Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
