Date/Time: Fri, 17 May 2024 20:08:41 +0000
sierra chart backup from previous trial
View Count: 625
[2017-07-02 03:52:30] |
User352645 - Posts: 2 |
Could you please send me my saved sierra platform with all my charts etc from your server from previous trial so I don't have to reformat platform again. I will be buying sierra charts and would like all my saved settings back please. Thanks |
[2017-07-02 05:08:59] |
What you are referring to are Chartbooks and these are stored on your local computer and not on the Sierra Chart servers. You should have these, as long as you did not delete your Sierra Chart installation from your previous trial. They can be opened with File >> Open Chartbook. Also refer to: Chartbooks (Workspaces): Accessing a Backup Chartbook File Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2017-07-02 07:23:31
