Date/Time: Sat, 18 May 2024 16:54:54 +0000
Draw style question
View Count: 1367
[2017-07-01 02:10:42] |
User968625 - Posts: 256 |
This might seem basic but I am struggling with it. I am using cumulative Sum of study to draw cumulative tick. I would like to know the draw style type that will allow me to see it as an increasing histogram or a mountain that is filling from zero up when he sum is positive and filling from zero down when it is negative. for example , Fill top works well if sum tick<zero but if sum tick> zero then I need to use Fill bottom. of course, I can't use both Thanks |
[2017-07-02 07:22:46] |
What symbol are you using the Cumulative Sum of Study on? If it is TICK-NYSE use Cumulative Adjusted Value instead. You will want to use these Draw Styles: Bar Fill to Zero Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2017-07-03 13:39:20] |
Thanks for the draw style. I am using IQFeed so the Symbol tick.Z, do I need to use the Cumulative Adjusted Value instead of the usual Cumulative sum of study? |
[2017-07-03 16:27:12] |
Yes we highly recommend that. You are going to get misleading information otherwise. Essentially nonsense.
Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2017-07-03 16:27:24
[2017-07-03 23:55:48] |
Ok but this one doesn't have reset at day start. Am I missing something? wouldn't be that the right thing to have if this study is the right one?
[2017-07-04 00:21:29] |
If you want to do this cumulative calculation for a single day, it is fine to use Cumulative Sum of Study. Over long periods of time, that simplified method can give you an inaccurate measurement.
[2017-07-04 00:23:48] |
Ok, was wondering why don't you add the option of reset at day start to Cumulative Adjusted Value and that way it is good for every period and for everyone
[2017-07-05 04:42:19] |
Just one out of thousands of tasks we have to do that we do not have time for.
[2017-07-05 13:21:47] |
Maybe if a lot of users are using cumulative tick then it is worth it as you have study adjusted for that (your program gives a different read then other program I use with IQfeed for reg one - e.g. IRT Linnsoft). understanding that there is no way to know how many users will be needing this then a simple logic can be applied and will lead to the simple conclusion that any user who is looking at market internals, many ES users usually try to see that - anecdotally of course, will try to explore that function. thank you for your help
