Date/Time: Mon, 13 May 2024 21:53:15 +0000
Indicator for number of bar low high or close?
View Count: 761
[2017-06-30 16:26:35] |
User15414 - Posts: 20 |
Is there an indicator which can show a 21 period low or close such as a bar that's low is lower than the last 21 bars? Or close is lower/higher than x number of previous bars?
[2017-06-30 17:23:15] |
Have a look at this study to see if it does what you need: http://www.sierrachart.com/index.php?page=doc/StudiesReference.php&ID=54#Highest_High_Lowest_Low_Over_N_Bars Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
