Date/Time: Tue, 14 May 2024 19:18:56 +0000
Color Bar Above/Below Study Hollow Bars??
View Count: 832
[2017-06-30 15:07:58] |
User509820 - Posts: 69 |
Hello, I am using the color bar based on above/below study. My original candles without the study have a candlestick UP fill hollow (same color as background). When using the study I would still like to see those hollow candles, so I can still distinguish up and down candles. Is this possible? Thanks
[2017-06-30 17:28:38] |
You just need to change the Draw Style of that particular Color Bar study to Color Bar Hollow: http://www.sierrachart.com/index.php?page=doc/ChartStudies.html#DrawStyle Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
