Date/Time: Tue, 14 May 2024 10:14:50 +0000
Pending orders not showing on chart
View Count: 822
[2017-06-30 13:59:40] |
User49270 - Posts: 48 |
Hi I'm in a position from yesterday that I entered using the chart dom. When I entered I had the target and stop set automatically, I shut my computer down yesterday and when I restarted today there is an order line showing on the chart but my target and stop order lines are not there. Thanks
[2017-06-30 16:44:28] |
Do you know if the Attached Orders had the Time in Force set as Day? This can be controlled as explained here: http://www.sierrachart.com/index.php?page=doc/AttachedOrders.html#TimeInForce Do you see the orders listed in the Trade >> Trade Orders and Positions >> Orders tab? Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2017-06-30 16:56:45] |
Time in force that is the problem it is set on day, thanks
