Date/Time: Wed, 15 May 2024 10:31:24 +0000
HIGHEST HIGH AND LOWESTLOW
View Count: 1200
[2017-06-30 13:30:57] |
User82615 - Posts: 106 |
HI COULD YOU PLEASE HELP ME WITH THIS ? , THE SAME WAY THAT WE GET THE FUNCTION HIGHEST HIGH OR THE LOWEST LOW OF A NUMBER OF BARS , WOULD IT BE POSSIBLE TO GET FOR EXAMPLE THE HIGHESTHIGH OR THE LOWESTLOW OF AN INDICATOR SUCH AS THE RSI?. IF YES COULD YOU GUIDE ME HOW TO DO IT PLEASE? THANK YOU VERY MUCH |
[2017-06-30 18:03:52] |
This can be accomplished with this study: http://www.sierrachart.com/index.php?page=doc/StudiesReference.php&ID=54#Highest_High_Lowest_Low_Over_N_Bars The documentation specifically mentions how this is done. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
