Date/Time: Tue, 14 May 2024 21:46:23 +0000
NYSE TICK
View Count: 1486
[2017-06-29 16:48:45] |
User269839 - Posts: 4 |
I have read several support threads regarding the accuracy of the tick data used by Sierra. I use IB as a broker and am also noticing large discrepancies. I am wondering if there is a way to use the IB data for tick rather than the sierra tick data. thanks, Lenny |
[2017-06-29 17:32:21] |
We are 110 percent convinced through careful study, that the Sierra Chart provided TICK calculations are absolutely perfect. You should question what the others are providing. It is the others who are providing faulty data at times. That has become abundantly clear. This is extensively explained here: http://www.sierrachart.com/index.php?page=doc/SCMarketStatistics.php#MarketStatCalculationsComparedToOtherDataServices And also here: Why Sierra Chart TICK-NYSE Market Statistic Calculation is Very Good You can use the Interactive Brokers symbols. Refer to: http://www.sierrachart.com/index.php?page=doc/IBSymbols.html You might also be interested in this new symbol: TICK-NYSE_NASDAQ_NYSEMKT which is a composite of all three US stock exchanges. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2017-06-29 20:06:05] |
I looked at the IB symbols thread that you provided, but do not see a tick symbol. Can you provide me the specific IB tick symbol that I need to use. Thanks, Lenny |
[2017-06-30 00:19:39] |
The symbol uses the standard Interactive Brokers Index symbol format. This is what you want to use: TICK-NYSE-IND-NYSE But you may have problems with this symbol. We have heard about it in the past. The statistics Sierra Chart delivers are rocksolid and are not going to give you any trouble. If you have problems with this other symbol, we will not help at all with it. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2017-06-30 00:19:59
