Date/Time: Tue, 14 May 2024 04:03:35 +0000
Bar size study
View Count: 860
[2017-06-29 16:40:36] |
pappe88 - Posts: 22 |
Is there a study which prints the size/range (high - low) of a bar? Or can I print that information somehow with number bars? Currently I have to use the chart calculation tool to check if I can trade that signal with my max stop. This is not terribly inconvenient but it often takes a tad to long in a fast moving market and I have to hurry. Thx bye |
[2017-06-29 17:30:27] |
Use the Bar Difference study for this: http://www.sierrachart.com/index.php?page=doc/StudiesReference.php&ID=56#Bar_Difference Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
