Date/Time: Wed, 15 May 2024 18:02:40 +0000
Color Bar
View Count: 854
[2017-06-29 15:02:04] |
User21113 - Posts: 62 |
Hi, I want to add a technical reference to a chart and then color the technical reference based on criteria. I want to color the technical reference not the price bars. Examples: 1. Add a volume study and color the volume bars greater than a certain value. 2. Add a Difference Study and color the Difference Bars based on above or below a value. Questions Can you use a color bar to color a technical reference study? Is there an alert you can use to color a technical reference? Thanks |
[2017-06-29 17:16:33] |
Yes this is supported with the Color Bar Based on Alert Condition study and is fully documented on this page here: http://www.sierrachart.com/index.php?page=doc/StudiesReference.php&ID=245#Color_Bar_Based_on_Alert_Condition Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
