Date/Time: Mon, 13 May 2024 21:13:00 +0000
spreadsheet formula question
View Count: 574
[2017-06-29 14:28:59] |
User498548 - Posts: 5 |
I would like to combine 2 formula on the spreadsheet but I dont know how it works. my 1st indicator formula works =(ID1.SG2@3>0) this is for Buy signal, Now I want to add Bollinger band to this formula: IF candlesticks passed the Bollinger band (upper band) then make an action. bollinger band upper band is ID3.SG1 Thanks |
[2017-06-29 17:34:58] |
Use the AND Spreadsheet function for this: http://www.sierrachart.com/index.php?page=doc/SpreadsheetFunctions.html#AND_Function Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
