Date/Time: Tue, 14 May 2024 16:07:46 +0000
Is it Possible to Create a Custom Spread of Two Listed Symbols that can be shown in a dom?
View Count: 601
[2017-06-29 07:52:02] |
User870825 - Posts: 3 |
Hi, Hopefully in the correct place now! I'd like to setup a user-defined spread of two listed symbols (i.e., the spread itself is not listed). Is this possible in Sierra so I can then view that spread in a DOM? Thanks, Sand. |
[2017-06-29 17:44:42] |
You can only do this in a chart. You can do this by using the Difference (Bar) study: http://www.sierrachart.com/index.php?page=doc/StudiesReference.php&ID=3#Difference_-_Bar Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
