Date/Time: Wed, 15 May 2024 14:01:15 +0000
universal renko
View Count: 710
[2017-06-27 16:11:50] |
Kenneth.S - Posts: 20 |
I have a chart using universal renko, however today it only did one bar although the range was way beyond the required range for a new bar. I have attached a screenshot I am using sierra chart 1558 |
2017-06-27_18-09-49.png / V - Attached On 2017-06-27 16:11:21 UTC - Size: 33.74 KB - 258 views |
[2017-06-27 17:31:18] |
This is due to faulty underlying data in some way. Either with the timestamps or prices. Right-click on the chart before that bar and select Delete and Download Data. Also make sure Sierra Chart is set to a tick by tick data configuration: http://www.sierrachart.com/index.php?page=doc/TickbyTickDataConfiguration.php Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2017-06-29 07:04:37] |
I did delete and download data - it didn't help. I am using the datafeed sold on your website. |
[2017-06-29 09:22:43] |
Now that we have run a test, we see the same thing. We will have to look into this. We are not sure though when we can get to this. Universal Renko bars are relatively new and are undocumented. We really recommend using normal Renko bars or Flex Renko bars. For now uncheck Chart >> Chart Settings >>New Bar at Session Start. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
