Date/Time: Fri, 03 May 2024 17:08:16 +0000
tpo and tpo value area lines
View Count: 1663
[2013-08-28 15:36:18] |
michael baksheev - Posts: 27 |
ive pulled up an intrady chart daily session and the tpo value area lines do not match up with the profile charts ive read the pages on how to rectify this but to o value they are just still out how do i fix this? And also if i want to do the same thing on a gap chart how do i set it up properly so they line up iam confused reading what to do and iv tried thing but to no use?
[2013-08-28 17:03:30] |
Provide us a Chartbook which contains two charts. One chart with the TPO Value Area Lines study and another chart with the TPO Profile Chart study and we will look at them and see what the problem is. Here are the instructions to provide the Chartbook: https://www.sierrachart.com/index.php?l=PostingInformation.php#AttachFile Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2013-08-29 13:39:59] |
playing with it more and got the tpo value area study to line up with the tpo charts just had to change tpo letter time in minutes to suit the tpo daily chart. still having some trouble with lining up the tpo gap chart with the normal gap chart have the same tpo letter time lenght in minute to the same tpo chart 30 min and there not lining up any suggestions? |
[2013-08-29 17:30:31] |
The fastest way for us to look into this would be to get your Chartbook so we can compare the chart settings and the study settings between the charts . Could you please provide that by following these steps: https://www.sierrachart.com/index.php?l=PostingInformation.php#AttachFile It should be a Chartbook that only contains the two charts you describe. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2013-08-29 17:30:53
