Date/Time: Fri, 10 May 2024 16:27:33 +0000
Multi-time frame indicators crossover and arrows
View Count: 1995
[2017-06-23 17:23:38] |
User479747 - Posts: 3 |
I know, It may sound like an odd request. I am a metatrader 4 user and now I am changing to a new broker (oneup trader) who offers me NinjaTrader and Sierra chart software. So I need to make a choice between the two. I have used as base strategy for day trading two main indicators. But now I cannot find them in neither ninjatrader or Sierra chart. I send you two attached files with the indicators I used for Mt4. I even have the source code. I am not sure if your team can port them to Sierra chart software. Let me know. Because I saw videos on youtube of Sierra Chart and I like it, it's just I need these indicators. Kind Regards, |
MT4 indicators.zip - Attached On 2017-06-23 17:22:43 UTC - Size: 35.52 KB - 259 views |
[2017-06-23 17:31:06] |
This request is not within the scope of our support. Are you interested in having this developed for an additional cost? It is not going to be inexpensive. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2017-06-23 17:31:25
[2017-06-23 17:53:39] |
Hi, Send me a private with the price and I will give you an answer. |
[2017-06-23 17:58:01] |
Contact Jim@sierrachart.com about this.
[2017-06-23 18:50:15] |
Is there any multi time frame indicator that comes included in the software?.
[2017-06-23 18:55:09] |
Yes. Refer to: http://www.sierrachart.com/index.php?page=doc/StudyPriceOverlayStudy.php Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
