Date/Time: Mon, 13 May 2024 05:08:56 +0000
touch gestures
View Count: 828
[2017-06-23 17:06:18] |
Kenneth.S - Posts: 20 |
I installed sierra chart on my surface pro, but I cant get sierra chart to react to touch gestures like swiping and pinching. How do I enable touch gestures in sierra chart?
[2017-06-23 17:10:21] |
Sierra Chart does work well with touchscreens, but only with standard interaction like you would do with the mouse. If you want to move the chart by the touchscreen, you will need to use the Hand tool: http://www.sierrachart.com/index.php?page=doc/Tools.html#Hand You cannot use two points and perform a zoom in or out. That is not supported. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
