Date/Time: Fri, 10 May 2024 12:01:40 +0000
Trade Activity Log
View Count: 722
[2017-06-23 12:56:28] |
sellis67 - Posts: 105 |
Hi, I've been using the Auto System Replay Backtest to check monthly totals on my charts. As per the attached trade activity log, the "Closed P/L" shows a monthly total of $62781.25 but a "Daily Net P/L in the negative column for everything but NQ. Is that an issue? Do the charts still generate the sub total? As per the setup instructions the data feed is disconnected, the auto trader is on 24/7, the sim trade data is cleared etc...please advise.
Scott_Ellis_Screen_Capture_Trade_Activity_Log_6.23.2017.png / V - Attached On 2017-06-23 12:56:02 UTC - Size: 91.73 KB - 224 views |
[2017-06-23 18:13:25] |
. Is that an issue? It is impossible for us to know the answer to this.Refer to: http://www.sierrachart.com/index.php?page=doc/DailyProfitLossValue.html Do the charts still generate the sub total? What do you mean by subtotal?, the sim trade data is cleared etc... This cannot be true if you see data on the Trade Statistics for Charts tab. If this were true, that tab would be blank.
