Date/Time: Mon, 29 Apr 2024 01:31:21 +0000
TT Fix no intraday data of actual day for EUREX futures (tested on the bonds and stox indices)
View Count: 1665
[2013-08-28 15:26:51] |
madmedmat - Posts: 13 |
after deleting / redownloading data -> blank screen. new bars are forming starting from then. data connection intact. EUREX only problem. e-minis load normally. can i fix this? can you fix this? thanks! |
[2013-08-28 16:35:24] |
EUREX historical data is not available when using TT. Longer-term we are working to develop a solution to this.
[2013-08-28 18:57:07] |
is this something new? i could swear i used that before (at least short term intraday history).
[2013-08-28 19:04:48] |
Sawtooth - Posts: 3982 |
Since June 1, 2013
[2013-08-29 12:08:52] |
thanks. any suggestions for a cheap solution? |
