Date/Time: Sun, 19 May 2024 17:11:10 +0000
how i can do this
View Count: 1325
[2013-08-28 15:09:36] |
redamardy - Posts: 5 |
hi please can you tell me how can i make this setup in merge point and figure and zig-zag and volume all to gather to make the setup which appeare in mane window (labeled by point and figure) in the chart attached Date Time Of Last Edit: 2013-08-28 15:11:01
AUD-CAD.png / V - Attached On 2013-08-28 15:09:12 UTC - Size: 111.02 KB - 472 views |
[2013-08-28 16:58:02] |
Refer to this section here: http://www.sierrachart.com/index.php?l=doc/doc_ChartStudies.html#OverlayingStudyOnMainPriceGraph We also recommend using Reversal Bars instead of a Point and Figure chart study: http://www.sierrachart.com/index.php?l=doc/doc_ChartSettings.html#ReversalInTicks Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2013-08-28 16:58:26
