Date/Time: Fri, 10 May 2024 20:45:03 +0000
Possible bug report
View Count: 728
[2017-06-22 07:39:53] |
BrMa - Posts: 77 |
Dear ladies & gentlemen, if I draw a retracement and open the retracement proberties to change the value for the Extend Multiplier, I can only enter one digit before the input field looses the focus. I need to click into the field again with every digit I want to enter... so entering the number 100 need 2 clicks at the right place after entering the field.... Can you confirm this? I'm using version 1568. Thanks a lot for checking! Regards, Markus |
[2017-06-22 18:02:36] |
This will be resolved in the next release.
