Date/Time: Fri, 10 May 2024 07:59:02 +0000
sc.BaseData[SC_BID_PRICE] not pulling Bid Price
View Count: 724
[2017-06-22 04:39:31] |
Joel Wisdo - Posts: 15 |
I am using sc.BaseData[SC_BID_PRICE] and for some reason it quit pulling the Bid Price. I stuffed it into an Index, and Simple moving average with length to 1 and anyway else I thought I could record it but it's O. I have sc.MaintainAdditionalChartDataArrays = 1; Any suggestions? I believe it was working early today as I had it in a formula but then my formula started producing weird numbers. I believe bc the Bid Price is not coming through.
[2017-06-22 05:04:51] |
Refer to the updated documentation for these: ACSIL Interface Members - Variables and Arrays: sc.BaseDataIn[][] / sc.BaseData[][] Most likely you need to set Sierra Chart for a tick by tick data configuration. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
