Date/Time: Sat, 11 May 2024 06:31:14 +0000
Trading: Position study does not update real time
View Count: 983
[2017-06-21 22:11:07] |
User299392 - Posts: 216 |
I have seen there is a lag if I were to call the position data from this study to Text Display study; where it shows up only 3 thru 10/15 seconds later than the actual position time. Please help. This is critical since I use this study to configure my spreadsheet study to call ongoing scale-in/scale-out moving average with partial P?L factored until a flat-to-flat position is attained. Unless tell me if Sierra is working on it. This is VERY IMPORTANT for me please. Or else please fix the above named study. Or any work around will also do. Thanks. |
[2017-06-22 05:03:07] |
The problem is on your side. Your computer's clock is wrong most likely. Refer to: Trading Information Windows: Trade Data Study Does Not Display Data or is Misaligned Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
