Date/Time: Sun, 28 Apr 2024 14:51:59 +0000
set up right margins on woodies panel
View Count: 1660
[2013-08-28 11:13:35] |
User20108 - Posts: 32 |
Hi I am using the woodies for range charts analysis panel and i cant adjust the margin or the space between price scale and candles.It is constant the same space. ~Which is the setting to adjust this?. Regards |
[2013-08-28 17:00:47] |
Go to the study named Woodies Panel by SC in Analysis >> Studies >> Studies to Graph. Adjust the Number of Fill Space Columns to your requirement. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2013-08-28 19:53:53] |
Hi I go to studies to graph/ but i am not sure which study i need to adjust. Please let me know as there are many studies in the woodies panel. |
[2013-08-28 21:45:48] |
As has been said it is Woodies Panel by SC.
