Date/Time: Sat, 18 May 2024 23:30:05 +0000
Getting enabled for recording audio alerts
View Count: 668
[2017-06-19 20:19:21] |
User508454 - Posts: 23 |
I've looked through the website support documentation and I see I have to be enabled for the ability to record audio alerts and pay a small fee per alert. How do I enable this feature on our account? Thank you, |
[2017-06-20 06:03:20] |
This service cannot be enabled on your particular Admin account because it is a reseller type account. You need to use the account that you use to log in to Sierra Chart with. Or any other account. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2017-06-20 12:09:04] |
ok, thank you.
