Date/Time: Sat, 11 May 2024 07:15:50 +0000
[User Discussion] - new feature request : study command line parameters
View Count: 694
[2017-06-19 16:37:21] |
jizzary - Posts: 177 |
Hi an idea came up to add felxibility to the study interface allow setting study "command line parameters" to the study at the time it is added to the chart's study list why required ? if you want to make the study trade many accounts - every time another account and you want to avoid recompiling to change the hard coded init values (not smart... not efficient) it could be great if i have few (e.g. 5) "command line" study's paramteres at the time i add the study then after during study's launch it may read these "command line" parameters which will direct/control its behavior this mechanism will add much felxibility to any study INI file and SQL DB table won't assist in case you want to run 2 or 3 studies concurrently as there is still the need to tell the studty the confuration ID it should load and this may be achieved thru the new interface i'm thinking about Date Time Of Last Edit: 2017-06-19 17:29:23
[2017-06-20 19:22:10] |
Not sure why this question is being asked. This is the whole idea behind study Inputs. Study inputs can also include strings as well. Refer to: http://www.sierrachart.com/index.php?page=doc/ACSIL_Members_scInputs.html We have nothing more to say. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2017-06-20 20:13:19] |
yes .. of cource I know the input fields and already using them my intention was different - but I'll manage suing the answer so pls see the issue closed |
