Date/Time: Wed, 15 May 2024 09:43:40 +0000
SMS messages for Spreadsheets
View Count: 583
[2017-06-19 14:26:39] |
User606491 - Posts: 164 |
I have multiple spreadsheet systems for trading on each chart. Currently, each systems sends me an alert and fires off an SMS text message. How do I change the settings so that only certain spreadsheets will fire off an SMS? Said differently, I only want certain spreadsheets to send me an SMS.
[2017-06-19 19:01:03] |
You need to use different Alert Numbers for each Spreadsheet. Refer to: http://www.sierrachart.com/index.php?page=doc/SpreadsheetStudyInputs.html#ColumnKLMNAlert And then you need to configure those particular Alert Numbers not to send an SMS message. Refer to: http://www.sierrachart.com/index.php?page=doc/GeneralSettings.html#AlertSoundSettings Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
