Date/Time: Fri, 10 May 2024 02:25:13 +0000
Alert Conditions on Volume Charts
View Count: 761
[2017-06-18 18:31:23] |
User172040 - Posts: 70 |
Hi, I'm trying to set an simple alert condition based on a 5000volume and 1000volume NQ chart. I'm trying to get a background color when all conditions on both the 5k and 1k are met. When I run the 5k 'script' on the 5k chart, it displays the background as it should. But when I add the Study/Price Overlay to the 1k chart and use the relevant ID and SG values, the background color does not populate. It's difficult to write about it without giving examples. Should I post the 'script' I've written? I've gone through the following page that was very helpful up to this point - Study/Chart Alerts And Scanning Thx |
[2017-06-18 18:39:09] |
the background color does not populate. Do you mean not at all? So there is no background at any chart bar colored?
[2017-06-18 18:45:35] |
No, the background color does populate when I run the 1000k and 5000k volume charts separately. However, when I try to combine the conditions of the 2 volume charts on the 1000k volume chart (by making use of the Study/Price Overlay) then I don't get any background color
[2017-06-21 01:56:45] |
Provide a Chartbook with no more than two charts, and no more than the necessary studies, which shows this. We will see what you are doing and what to do to resolve this. Here are instructions to attach the Chartbook: https://www.sierrachart.com/index.php?page=PostingInformation.php#AttachFile Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2017-06-21 05:46:46] |
I resolved this. Thx
