Date/Time: Tue, 30 Apr 2024 12:40:18 +0000
how to avoid the drawings out of place?
View Count: 880
[2017-06-18 02:50:04] |
user8888 - Posts: 159 |
Hello Support, is it posible to avoid this thing, I mean when you draw lines, fibonaccis, etc ..., then comes the contract rollover and all those drawings are out of place ... Thank you |
[2017-06-18 04:39:38] |
You just need to adjust them. Refer to: Changing to a New Futures Contract Month: Adjusting Chart Drawings to Match Futures Contract Rollover Difference Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2018-09-14 03:41:32] |
whats1thingnow - Posts: 407 |
i thought the chart drawings are automatically adjusted when we use the "chart > perform symbols rollover" function and it asks to roll over drawings to new symbol...
[2018-09-14 06:23:47] |
There is no automatic adjustment of the prices. Only the symbol of the drawings is updated to the new futures contract symbol.
[2018-09-14 09:08:05] |
Cavalry3162 - Posts: 523 |
that sounds like a great enhancement though @SC as you already know the adjustment amount (as you do it in a back adjusted chart) you might "roll over" and adjust drawings as well.. maybe as an option in the drawing? |
[2018-09-14 22:59:39] |
+1 to post #5
[2018-12-14 06:12:17] |
any news on #5? in the mean time, how do we find out the exact amount to adjust from old to the new? sorry for the newbie question :( |
[2018-12-19 03:50:47] |
bump
