Date/Time: Tue, 30 Apr 2024 08:54:21 +0000
Continuous contract - difference in weekly and monthly
View Count: 1331
[2013-08-27 21:53:36] |
Allan Stevenson - Posts: 9 |
Still new to SC, thanks for your help I've loaded a monthly and weekly chart for 6E and both are set to continuous contract in settings. The most recent month high is different between the charts, see attached ... 13400 in monthly compared to 13454 in the weekly. If I uncheck continous contract in the monthly then the same high is shown. Can you explain this please? Images attached. Thanks |
27-08-2013 22-42-45 6E weekly.png / V - Attached On 2013-08-27 21:53:06 UTC - Size: 91.46 KB - 445 views 27-08-2013 22-50-49 6E Monthly.png / V - Attached On 2013-08-27 21:53:10 UTC - Size: 94.92 KB - 422 views Attachment Deleted. |
[2013-08-27 23:36:09] |
There is an apparent problem with the Continuous Futures Contract option on a monthly chart. This is something that has not been tested previously. We will have to look at this when we can.
