Date/Time: Sun, 19 May 2024 17:52:27 +0000
Time of last trade in bar
View Count: 928
[2017-06-15 16:12:13] |
wwwingman - Posts: 185 |
Hi I use sc.BaseDateTimeIn[] for time at open of bars. Is there a way to get the time of close of the bar (or last trade in the bar..) ? -- W. |
[2017-06-15 17:11:45] |
You need to use this ACSIL member: ACSIL Interface Members - Variables and Arrays: sc.LatestDateTimeForLastBar Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2017-06-15 17:21:06] |
as far as I can see the sc.LatestDateTimeForLastBar works only on the current last bar unlike sc.BaseDateTimeIn[] that gives the open of ALL barS -- W Date Time Of Last Edit: 2017-06-15 17:21:19
[2017-06-15 17:38:49] |
Yes it is only for the last bar in the chart. That is correct.
[2017-06-15 17:46:23] |
It is on our task list to add a new array which does contain the last Date-Time of each bar. We will try to get that into the next release.
[2017-06-30 07:47:13] |
Note for other programmers, The bar End time is available as of version 1575 : Added new sc.BaseDataEndDateTime array to ACSIL which contains the ending date time for each chart bar. This requires setting sc.MaintainAdditionalChartDataArrays to 1 to cause this data to be maintained.
[2017-07-17 22:24:31] |
@sstfrederik - Posts: 404 |
I have been testing this and see that there can be quite some difference between the end time of a bar and the subsequent start of a new bar. Varying between 1 and 12 seconds. Is this normal? Edit. This was on a 15 min chart. Date Time Of Last Edit: 2017-07-17 22:29:39
[2017-07-17 22:51:28] |
Yes this is completely normal and expected. It can even be longer than that.
