Date/Time: Sat, 18 May 2024 23:12:23 +0000
AddAsUserDrawnDrawing drawings are not persistent
View Count: 873
[2017-06-15 03:08:02] |
User735389 - Posts: 188 |
With AddAsUserDrawnDrawing = 1, are drawings suppose to persist even if the chartbook is reloaded? That was the anticipated (and desired) behavior based on what i read, but drawings are disappearing when the chartbook is closed. The drawings can be modified after being created with sc_tool, so it does appear to be set as a userdrawndrawing.
[2017-06-15 03:18:31] |
Forgot to mention that I also have AllowSaveToChartbook = 1
[2017-06-15 03:45:35] |
I also just tried the test study from this thread: Delete user drawings in "LastCallToFunction" Even after adding AllowSaveToChartbook = 1, the drawing is not saved after the study has been removed. |
[2017-06-15 04:06:37] |
We see what the problem is. This is now corrected and will be out in the next release hopefully this evening. There was some old chart drawing related code that needed to be cleaned up to allow this to work properly. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2017-06-15 05:05:27] |
perfect, thanks you!
[2017-06-15 06:12:05] |
We have now released version 1570. Let us know if there are any further issues with this. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2017-06-15 06:12:14
