Date/Time: Sat, 18 May 2024 20:43:44 +0000
Change display value with cqg
View Count: 849
[2017-06-14 22:17:24] |
User84163 - Posts: 17 |
Wondering how I can get value to display on yen chart like this if possible. Would like it to display without the .00
Attachment Deleted. IMG_2793.PNG / V - Attached On 2017-06-14 22:15:08 UTC - Size: 31.11 KB - 239 views IMG_2794.JPG / V - Attached On 2017-06-14 22:15:20 UTC - Size: 199.46 KB - 304 views |
[2017-06-15 06:02:14] |
This can be controlled through the Real-time Price Multiplier chart setting: Chart Settings: Real-Time Price Multiplier (Chart >> Chart Settings >> Symbol >> Symbol Settings menu) Be sure to read the documentation because you will also have to change the Tick Size and Price Display Format settings. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
