Date/Time: Sat, 18 May 2024 21:55:31 +0000
Trade DOM Recenter Line
View Count: 1192
[2017-06-14 15:03:40] |
User46129 - Posts: 22 |
Sorry for another dumb question, but would like to place 'recenter line' at top of row, vs through the middle of numbers. Is this possible? The edit options are blanked out in Global and local preferences...
2017-06-14_0959.png / V - Attached On 2017-06-14 15:01:48 UTC - Size: 56.58 KB - 328 views 2017-06-14_0958.png / V - Attached On 2017-06-14 15:02:04 UTC - Size: 34.67 KB - 319 views |
[2017-06-14 16:31:13] |
We will be doing some work on this later but specifically what you are looking for is not supported.
[2017-06-14 16:41:48] |
Okay, no problem... if placing the line between rows is difficult, or not possible, maybe just give an option to lighten the line, change it to dots, etc.. Thanks!
[2017-06-14 18:53:50] |
We will be adjusting the line between the rows.
