Date/Time: Sat, 18 May 2024 18:03:00 +0000
Cumulative Delta
View Count: 1106
[2017-06-14 03:06:52] |
User713688 - Posts: 25 |
Cant figure out how to pin the Cumulative Delta to the zero line like the picture below. Can anyone help me with this? Thanks |
ESCDELTA.jpg / V - Attached On 2017-06-14 03:04:26 UTC - Size: 135.73 KB - 348 views Attachment Deleted. |
[2017-06-14 06:08:16] |
Looking at that chart, this is not supported in Sierra Chart. The Cumulative Delta Bars study does function properly and in a proper way. You should not try to want it to function differently in a way which would not make any sense. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2017-06-14 06:08:47
[2017-06-14 06:26:47] |
Can you please direct me on how to make it happen? Or are you saying its not possible with the tools readily available? Thanks |
[2017-06-14 06:40:51] |
gomifromparis - Posts: 244 |
This seems to be a non-cumulative delta bar, that's what they all start at 0. Not sure how it can be done in Sierra though |
[2017-06-14 06:56:33] |
I think youre right. It cant be a cum delta bar. Im thinking perhaps its just the AskV - BidV turned into a bar
[2017-06-14 06:58:51] |
Figured it out. Thanks for helping me figure out I was searching for the wrong thing. Its a study called Ask/Bid Volume Difference Bars.
[2017-06-14 11:02:36] |
User41683 - Posts: 37 |
Haha, funny that even Sierra Chart Engineering didn't recognized it.
[2017-06-14 19:28:55] |
Yes, post #6 is correct. We did not know that is what you wanted because you made reference to " Cumulative". Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
