Date/Time: Sun, 19 May 2024 11:41:43 +0000
SC Real Time data feed
View Count: 671
[2017-06-13 14:51:42] |
User14683 - Posts: 34 |
Can you please explain what is "1st connection"? "The following is the pricing for the data feed. Real-time exchange fees are an additional cost. For 100 Real-Time Symbols: 1st connection 35 USD/month. 2nd connection 20 USD/month. 3rd connection 20 USD/month." Will a 2nd instance of SC opened on the same computer be a 2nd connection? |
[2017-06-13 15:57:52] |
Each connection is used by a separate copy of Sierra Chart. Will a 2nd instance of SC opened on the same computer be a 2nd connection? Yes. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2017-06-14 01:10:21] |
Merlin - Posts: 81 |
I recall reading that if one SC instance is accessing futures only, and the 2nd one is accessing stocks only, that special case will not count as a 2nd connection. Is this still true?
[2017-06-14 01:31:59] |
Yes, this is correct.
