Date/Time: Fri, 13 Nov 2026 09:43:57 +0000
SierraChart fails to connect entry and close trades
View Count: 1324
| [2017-06-13 14:03:26] |
| Peter Power - Posts: 70 |
Hello, I am experiencing difficulties when trading live. I am connected via API to TWS. My trades are not connecting properly causing confusion whether I am in trade or not. When I enter the trade, the entry line disappears after few seconds and when my trade reaches profit target/SL it behaves like if I would enter a new trade. Any suggestions? |
| [2017-06-13 17:28:32] |
This is a common ongoing problem with Interactive Brokers. It is documented here: http://www.sierrachart.com/index.php?page=doc/InteractiveBrokers.php#TradePositionLineQuantityDisappearingDisplayingZero In regards to connecting lines between order fills, with an issue like this, those will not work correctly because the Open/Close for the order fill will not be correct. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2017-06-13 17:30:25
