Date/Time: Sun, 19 May 2024 06:11:29 +0000
Study/ Price Overlay - switch off Labels
View Count: 670
[2017-06-13 08:58:28] |
nicktrader - Posts: 665 |
To see the VWAP in the DOM I use the above mentioned Study. I take the VWAP from my current chart. Is there a way to switch off both labels (Name and Value) in the DOM? In the source chart I need the settings of the labels. |
Study Price Overlay in DOM.png / V - Attached On 2017-06-13 08:53:57 UTC - Size: 122.49 KB - 243 views |
[2017-06-13 17:38:56] |
No, there is not a way to do this. But we will add a new Input to the study to support this.
