Date/Time: Thu, 16 May 2024 14:30:22 +0000
Spreadsheet System for Trading Newbie Question
View Count: 750
[2017-06-12 21:49:36] |
RonW - Posts: 103 |
All of the videos I have watched say that when you enter a formula in the Buy Entry column in Cell K3, the rows in Column K greater than 3 will populate with the formula. I typed the following in K3: =ID0.SG3@3<=ID1.SG2@3 and the other rows in Column K did not populate. What am I missing? Thanks |
[2017-06-13 05:38:23] |
For the formula to automatically fill down a Sheet column, you need to enable the following option in Global Settings >> Spreadsheet Settings: Global Settings Menu: Spreadsheet Settings (Global Settings menu) Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
