Date/Time: Thu, 16 May 2024 10:45:39 +0000
chart drawing, right margin
View Count: 3042
[2017-06-12 18:27:43] |
User989712 - Posts: 27 |
Hello, 1) Is there a way to set a fixed (empty) margin on the right side of a chart? Because the bars are drawing right against the Y Axis. I need to have some visual space between the bar being drawn and the axis. It appears that scroll bar will move the margin, but this is not a standard windows behavior, and it is not "sticky", it does not stay. I move around a lot on the chart and the scroll bar is not a practical solution for me 2)I would like to have the draw tool not stay in draw mode, but return to a chose base state (pointer or crosshair) after ONE drawing. I usually only want to draw one figure at a time, not a sequence. Is there a way to do this? I am coming from another charting package. Of course each will have its strong points...I need to find ways to do things like this in Sierra Chart. Thanks |
[2017-06-12 19:42:22] |
1. Refer to: http://www.sierrachart.com/index.php?page=doc/WorkingWithCharts.html#FillSpace 2. You need to use the After Single Tool Use Change To setting: http://www.sierrachart.com/index.php?page=doc/Tools.html#GeneralToolOptionSettings Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2017-06-13 00:48:01] |
Thanks. By the way, it would be great to have the documentation in a download PDF...probably would be easier to find. Of course there are reasons not to do this. I quite like your software. Wish I didn't have so much code already in C#. :-) |
